driveline chatter at take off
bodydropped72
with the 2 link setup i got on my titan i get mild to annoying driveline chatter when i take off from a stop it has a 2 piece driveline and im not sure how to fix this how do i go about setting my pinion angles?
BioMax's avatar
BioMax
Setting your pinion angle on any custom system totally depends on how the system was originally set up by the builder. If your rearend is bolted to the 2-link via u-bolts, then you can buy degree-shims and change the angle like that. Otherwise, without seeing the system,I couldn't tell you.
pewter2000
mine does the same,i got a pp 6 link on a 2000 silverado.if i try to do a powerbrake burnout,my rear hops like a bitch!!!i hate it!
DOWNSUB's avatar
DOWNSUB
like BIO said pinion angle ^
bodydropped72
its is bolted up with u bolts what about the angle for the pinion what do i go off of the carrier bearing joint or the trans and i know it should be set at ride height
FullSizeRST's avatar
FullSizeRST
mine did the same thing wich is why i got ride of mine! every time i would floor board it the ass end of the truck would slam down and i would crush the rubber bushings
ganksta's avatar
ganksta
isnt typically pinon angle on a one piece need to be the same as what the angle is out of the tranny for instance if the angle out of the tranny is -5degrees, n im just throwing a number.... then at the dif it should be +5degrees in order to be correct?
BioMax's avatar
BioMax
There has been so many threads about this subject, do a search.
