need help titan wont start
dragginon22s
I just moved the battery on my 08 nissan titan getting ready to bag it and now i can get my truck to start. All it does is makes a clicking noise and doesnt turn over.
FoolInjected's avatar
FoolInjected
make sure your ground is making a good connection and the paint has been removed from your ground point
dragginon22s
ok i got a ground on the frame in the back and a ground on the motor like ti had. plus 0 ga power wire for the power. so i dunno what else to do.
dragginon22s
bump
pugz's avatar
pugz
the 08 titans have "chipped" keys. its possible that u decoded the key. if so youll have to take it to the dealer and reprogram the key to the truck. they usually charge 1 hour of labor for it. so up to 85$. its a possibility
thacru78's avatar
thacru78
Make sure all the wires are connected to the battery....this happened to me a while back on a 06 Chevy....I was already shopping for replacement CPU's when I was moving the truck and just so happened to see a wire was dangling off the battery. Good luck man...hope you get it working.
dragginon22s
i got it working, i ended up have to put 2 ground on the battery the one from the motor and one on the frame in the back never had to problem before. but it could be from where the ground off the motor has some sort of plastic connector on it the run in to the harness.
