got the shakes BADD
got the shakes BADD
Suicide_blazer
well im hoping this section will produce answers for me. i have a chevy blazer xtreme its bagged with 20s KP 4 link. normal driving is fine but above 40mph my steering wheel vibrates BAD my arm shakes like crazy and you can feel the whole blazer shaking and you can see the dash vibrating. also over 55 or under hard acceloration in the 50mph range my blaze will wobble side to side and i meen bad to the point where unless im at full lift my bumpers start hitting the ground left to right. when i bring the front all the way up and slow down it will help but i just dont feel safe driving like this. what should i look for what could be causing this? i got an allignment awhile back and havint done anything to the suspension sence. any help would be great!!!
corey0814's avatar
corey0814
it could be a bunch of things. bad wheel bearing(s), a cracked or misaligned bearing race(s), bad balljoint(s), bad tie rod link end(s), loose bolts or nuts, loose hub nut...the list could go on & on. i've even seen a warped brake rotor do that even if the pedal wasn't depressed. also a cracked caliper piston could do that. hell even an out of balance wheel...
i'd jack it up & shake the wheel & look for loose hardware &/or defective parts.
hopefully you get someone else that will chime in that's seen this before to this degree. although i've seen all of the above cause front end vibration, i've never seen or heard of any of them shaking the vehicle THAT violently! good luck man & BE SAFE!
Suicide_blazer
thankfull this isnt my daily driver so its being parked i checked the wheels and there doin good there balanced the brakes are good no warped rotors or anything like that, ill check the tie rods see if that might do it. thanks for the tips!
1lowrado's avatar
1lowrado
how about pinion angle?
BioMax's avatar
BioMax
Can you lift the truck to where you are experiencing these problems and post a picture of the rear suspension at that height?
draggin95niss's avatar
draggin95niss
maybe a bad tire....mine shook like that and i bought tires and its all cured but i have a nissan....
Suicide_blazer
the thing is when its at full lift i have no real problems its when its not at full lift i get shakes, ill take as many good pics as possible for you all. thanks for the responces!!!! how do i check pinion angle honestly dont know much about it if u could illaberate on that it would be great thanks!
ShakinPlates's avatar
ShakinPlates
Put it on jacks and freely spin the tires and see if you get any type of vibration. Id start there first
Suicide_blazer
ok ill try that thanks bro
drivewaycustoms's avatar
drivewaycustoms
have you gotten the wheels balanced,mine was doing something similar,some the weights had fallen off.
