yota question
louis_curl@yahoo.com's avatar
yota question
societyoutkast's avatar
societyoutkast
alright well with the lights on like at night or the ac on the highest level wich i hardly use the ac but still with lights on and driving it seems like its starting to lug the motor but when i hit the blinker to turn it has like a joilt its real quick but today i did have to adjust my throttle linkage cause it was idling way low cause the idler adjuster screw broke and a new one in 900 bux but still has anybody ever had this joilt ???
TwistedMinis's avatar
TwistedMinis
A jolt like what? My alternator died a while back, and I had my headlights on, the stereo real loud, and the compressor running. I went to turn on the turn signal and my stereo and compressor turned off and the truck shut down.
I had no idea the alternator was bad until that point, it started fine just before that happened (within minutes).
bodydropped85's avatar
bodydropped85
def sounds to me like your alt. is goin bad, or you have a bad ground from the chassis to body.
societyoutkast
alright so ive narrowed it down a bit more it does it when i have the headlights on and i put the blinker on if i just use no lights and use the blinker it dont do it ???
SoloSpecialties's avatar
SoloSpecialties
alternator
societyoutkast
but wouldnt my battery be dead by now ??? been doin it for 3 days now
projectneverdone
Not to jack your thread. Im having and issue with directionals and head lights as well. When ever i put my left side directional on it works fine then i turn head the lights on the directional stays on until i shut the switch back to middle position. the right side directional blinks real fast like the bulb is out. Ive replaces the flasher under the dash. Still same deal. IM lost on this one any ideas
projectneverdone
anybody have any idea?
