4 link / bag?
lowdownin94@yahoo.com's avatar
4 link / bag?
low downin's avatar
low downin
so im now in the process of bagging the rear of my toyota. centered the nothces at ride height but when layed out the axle is offset an inch and a quater from center. is this bad or what? if not will it f up the bag? thank for any help
low downin's avatar
low downin
anybody?
FullSizeRST's avatar
FullSizeRST
do you have your pan hard bar correct?
low downin's avatar
low downin
may have miss wrote my question. when layed the axle moves forward an inch and quater, through the arch. thanks
9
90slammedmitsu
your bags will be ok if u set the bags up when your laid out
lobdyblazr
sounds like your front mounts are too low on the truck.
low downin's avatar
low downin
yeh they were way low changed the ride height. cant get much lower.going to have a little deflection on the bag i think
BioMax's avatar
BioMax
Firestone allows as much as 1" of misalignment per bellow. What that means is that on a standard 2 bellow bag, the top and bottom plates can be as much as 2" off-center from each other.
low downin's avatar
low downin
thanks for the info does anyone know about slams
s10
last post by baha +1y
