318 in a BD Hardbody
rob_lervold@yahoo.com's avatar
Rob Clayhill's avatar
Rob Clayhill
i just bought a dodge 318 built up a little for my hardbody that ive just started to work on. im bodydropping it to the rocker and want to keep a stock hood, looking to see if anybody knows anything about this swap...
SinistarCustoms's avatar
SinistarCustoms
FUCK YEAH! Something different! I was Just joking around with my boy Bobby telling him to drop a Dodge in his Hardbody. Hes stuck on a 4.3 Chevy though
Rob Clayhill
yeah, i was going for the 302 swap until i came across a deal so good i couldnt pass up.
only thing is i cant seem to find anybody thats done the swap
gettwisted07's avatar
gettwisted07
I've done a chevy 350 small block motor swap. still have the stock hood and its bodydropped to the pinch. its not that bad. not sure about them dodge motors though.
boooghar's avatar
boooghar
you're best bet would to buy a set of univerisal motor mounts from a place like speedway motorsports for a hot rod (unless you want to solid mount it to your frame which i would not recommend) along with a trany mount. btw what kinda tranny are you going to use ? a torqueflight 727 ?
dragggn's avatar
dragggn
Edited: 8/17/2008 5:36:26 PM by dragggn
OMG ^^^^^^^^^ Bad Ass Ride ^^^^^^ (layin 22's hardbody style (gettwisted07))
gettwisted07
haha. thanks alot. I built motor mounts for the motor and tranny mount. the motor mounts are solid and have kinda like a 4link bushing. tranny crossmember is the factory center bolt from GM and i just built a new tubular mount.
pugz's avatar
pugz
theres alot of people runnign v8s in hardbodys with stock hoods. never seen a dodge motor in one though. theres how to v8 hardbody buildups on nissancustoms.com though. but more for the 350s but could be some helpful info
Low_SST's avatar
Low_SST
fyi that 318 is going to be a taller motor then a 350 or 305. You may run into clearance issues.
Rob Clayhill
clearance is the only thing im conserned about. the oil pan sum drops toward in the front of the motor, not the rear like 350's. any ideas on what would be needed in order to clear the crossmember and steering linkage?
