Im looking at ebay at some of these wheels but why does the price vary sooo much on these? Im looking for 22.5's classics and im just soo confused lol
krewzlo
Search, there are lots of topics on them. The is a pinned thread too
comegetsome
Price varies so much depending on what wheels have done to them....milled, custom, cut, 22s, 24s, adaptors.....the truck your lookin at is bagged so your gonna need a 22 not a 22.5 like you mention in your other post....1/2 an inch is milled off a 22.5 to make the 22s you need...milling is expensive is why the price is higher.....the smallest tire you will be able to find for a 22.5 is about 37-38 inches tall and will not fit very well under a bagged truck....once you mill them down to 22s you can run and standard size smaller car tire....my dually has 265/35-22 tires on it and i would recommend about the same for any bagged dually....custom cut designs adds alot to price....also adaptors to bolt them on are gonna cost you between 750-1000 bucks...also 22s are alot wider on rear end than the 16s so the rear fenders will need to be cut, widened, and refiberglassed or a shorter rear end which will most likely result in the 4 link needing to be modified....its alot of work to get semi's under a bagged dually alot of people think they just bolt on a ride out but thats not the case at all....hope that helps alittle
