Stupid Question
ERI454@YAHOO.COM's avatar
Stupid Question
ERIC-B's avatar
ERIC-B
What
dragggn's avatar
dragggn
I've always gone with the front hubs,, but of course the wheels need to be straight , so i guess that leaves room for error.
I suppose you already pulled the axle, and axle mounts, so you cant get a "before" measurement???
ERIC-B's avatar
ERIC-B
It had a 4 link on it already. Everything from the leaf springs was cut off. I'm in the process of redoing the 4 link.
BioMax's avatar
BioMax
Unfortunately there isn't a difinitive answer to that one. I have measured from anything and everything and have still had to compromise on the measurements. Just start measureing from stuff and see what works.
standardbyker88's avatar
standardbyker88
knowing the wheelbase helps though.
N
Narz
Edited: 8/18/2008 6:26:26 AM by Narly
i have measured from the lower ball joint castle nut.. the center.. usually wont effect the measurement too much if the wheel isnt completely straight.. if at all.
dragthatbitch
yeah, upper or lower ball joints are a good place. Just level both arms first
BioMax's avatar
BioMax
It's not good practice to use a moving suspension part to take measurements from. Sometimes, both the upper and lower arms are adjustable and can give bad measurements. Try to stick with factory stamped holes in the frame or something along that line.
Also, knowing the wheel base doesn't help much either. A lot of trucks don't have their wheels centered in the wheel wells, so blindly trusting stock wheel base measurements is not a good idea.
bodydropped85's avatar
bodydropped85
i usually go by the front bed mount holes, or front leaf spring perch holes.
