emergancy brake light is on??
lostcause@blomand.net's avatar
lost cause's avatar
lost cause
I know this usually means your altinator is bad right
Well today I tubbed my taco and relocated a few things,....like my Fuse box,...Battery,...and the charcoal canister........And to make a long story short, when I put everything back together and stared mmy truck the emergancy brake light was on and won't go off???
any Ideas....
I haven't had an e-brake on this truck for quite a while btw,...if that helps anything?
thanks guys
bodydropped85's avatar
bodydropped85
check your brake fluid. if it has a level sensor in the master cylinder, it could be stuck to.
tweak
my truck did it one time.it was the switch behind the e-brake wasn't engaged or like James said could be the brake fuild too.hope this helps
jhouk2000
Ussually the brake and the battery light will come on if its an alternator problem.
lost cause's avatar
lost cause
^^^^That might be it,....I had to disconect that sensor when I was moving things around, I'll check that first thing tomarrow! Thanks James!
bodydropped85
no prob, what would u do without me
jdm customs's avatar
jdm customs
yep prolly didnt hook it back up. or not all the way. we shall see.
overkillFFF's avatar
overkillFFF
could possibly be the wire for your e-brake switch. If it's grounding out your e-brake light will come on.
overkillFFF
bobogolfcart's avatar
bobogolfcart
if the fluid is low it doesnt mean "just top it off" the fluid stays in the lines and as your brake pads/shoes wear down it uses more fluid to push the pads (possibly need new brake pads)
