Air Ride Suspensions \  using copper hardline
Air Ride Suspensions Q & A
views 4326
replies 18
following 18
tuckinlugs06   +1y
is there any cons to running copper line
CommonVan   +1y
use the right fittings and buy a good bender.
OldSkool720   +1y
i was actually thinking about doing that to, it would be pretty cool
koolrunner   +1y
copper line will harden after time. if you need to get it a bit softer (more flexible)just heat it good and hot(red) with a torch and let it cool. it's much easier to bend then.DON'T use for fuel or brakes.
baggedexpo   +1y
I have copper lines on mine and you never have to woryy about a plastic line breking or ripping. The only bad thing it that they tend to rattle at times depending if your ride is bumpy or rough.
grillift   +1y
what fittings are you guys using?
94NissanLaysDoor   +1y
Edited: 9/8/2008 6:56:01 PM by 94NissanLaysDoor
Doesn't anyone use the "Search" Feature.....?There has been ALOT of threads on this...
CLNSHVNnDRAGGN   +1y
I use the all nickel push to connect fittings. They aren't very cheap but I've never had an issue with them with copper or plastic/nylon line.
lucky_brew   +1y
is there anything you can do to make the copper line look... well... not so copper. like paint it or something? i like hard line but every time i see it on a truck i think of my bathroom sink.
tacokane   +1y
Anybody used the flexable copper line before? Can it handle the same pressure, and what about heating the ends of the copper line and sodering them as you would a hot water heater. Any thoughts on this technique
