Keg as a gas tank
Deezy1973@wmconnect.com's avatar
Keg as a gas tank
OldSkool720's avatar
OldSkool720
Im in the middle of doing my suspension and i have an old keg layin around and thought about using it as a gas tank, and i have a few questions. Is it worth doing, how did u clean it out, and where did u get your lines from? Thanks
scotto79
sure its worth doing, hot water would probably work fine, rinse it out a few times and let it dry, and you could just get fuel lines from Summit Racing, either steel braided or rubber and the fittings.
bodydropped85's avatar
bodydropped85
wash it out with acetone.
z71mazda's avatar
z71mazda
there is a chemical out there for that type thing and its not all that expensive and it coats the inside of the tank its called RED-KOTE you can get it at any oreilly auto parts store
Forever Draggin's avatar
Forever Draggin
check out por15.com they make a gas tank sealent and a cleaner, i used it when i had built a steel gas tank and u pour the cleaner in there and its an acid that cleans everything and u pour the sealer and swish it around and then pour it back out and it coats the inside real good. my tank is 2 years old and havent rusted one bit.
BioMax's avatar
BioMax
The keg shouldn't need to be coated because they are designed to hold a lot of pressure and they are also stainless steel so they won't rust. Running lines will be tricky and so will a filler neck unless you are used to working with stainless. You will need to come up with something solid to mount the tank because stainless is finicky about stress.
WF
Wicked Fantacies
^ exactly if you do end up doing so make sure who ever welds has welded stainless before because it can walk on you real easy.
We got a "Pabst" KEG were gonna do in my buddys van. Havent figured out a location yet.
pugz's avatar
pugz
ive seen it done. it looks sweet. prolly a bitch to run but badd ass when done
