Ask A Pro \  I'm a noob, so here goes....
Ask A Pro Q & A
views 200
replies 6
following 5
2ndChance   +1y
OK, I bought a 98 frontier that was already bagged & it had a vibration when I pulled out, so I am going to redo the 4 link. It had 2 bars to the front, 2 bars to the back, & bags mounted over the axle setup. I have looked everywhere & everyone says reverse 4 links are crap. Do I still need to move the 4 bars foward even though the bags are mounted on top of the axle? Then all Ill have to do is move the gas tank, right? Some pics would also be a big help! Thanks!
waynehammer   +1y
the vibration may not be caused by the links. but it gan be a bunch of things.. check ur driveshaft.. has it been cut? thats why i just got my 72 toyota so cheap, the guy couldnt figure out why it vibrated so bad. haha it only had 1 bolt holding the driveshaft to the rear end
2ndChance   +1y
it just vibrates when i pull out, then it stops!
BioMax   +1y
It sounds like it just needs the pinion angle fixed. Unfortunately though on a 2-forward/2-reverse 4-link it isn't always that simple. If you are going to spend the time re-linking the truck it would be a waste of time and material to build a reverse 4-link. They will hold the truck off of the ground, but that is all they are good for.
Wicked Fantacies   +1y
It may help to post a pic of ur setup to see if it is pinion not that u can always tell but it may help
granth   +1y
contact a shop in your area and have them check it out, they will be able to tell you if its your actual setup or something else. don't think its the worst until you have checked the basics.
2ndChance   +1y
well, about the pic post the 4-link is already took out... I was asking because I didnt want to have more work than was needed to be done. But I will bit the bullet & do it foward. Does anyonr have any pics of forward links on a frontier? Thanks for everyones help!
