Chevy/GMC Trucks \  Spindles for 90 Fullsize Regular Cab
views 147
replies 5
following 5
do_spiderman   +1y
OK, need to know which spindle for a 1990 Chevy Fullsize Reg Cab from Belltech and why they make two that according to Belltech both fit that year.
2500BLT&2400BLT
Anyone have a clue?
dirkbelt   +1y
maby one is a 2" spindle and the other is a 3".....not sure tho
corey0814   +1y
i can't give you a definative answer, but my belltech static drop kit for my truck had 2 part #'s also & i found out it's because one was for 3/4 ton, & the other was for the 1 ton
i had to call the company directly for that answer (no ammount of google helped me), so i'd suggest giving them a call
do_spiderman   +1y
Thanks.
SeeinStars   +1y
I know with Mcgaughys there are different spindles depending on which rotors you have. There is a 1" rotor and there is a 1 1/4" rotor... Both use different spindles.
Belltech has a bump steer issue, I would go with Mcgaughys. If you want to give me a call I will give you a good price on some Mcgaughys.
602-258-0088
-Elaine
low10   +1y
richard,i took a look on the belltech website and here is what is says.The 2500 is a 2" drop for years 1992-1998 the 2400 is a 2" drop also but it is for years 88-91.So by your post and there guide i would go with the 2400 series.
