best Heim Joints
McClarysmetalworks@gmail.com's avatar
best Heim Joints
McClarys's avatar
McClarys
as a shop, im always looking for the better of the products....ive had customers in the past wanting 4link setup with bushings on frame and Heims on Axles.....so , im looking for Personal Experience from shops or Owners on Heim joints...whats brands seems to work best ....any links to sites that sells the brand.maybe even sites that Wholesales parts for shops.and what size do you guys tend to like better ?
thanks for any input....
mat
BioMax's avatar
BioMax
Jack at hm-engineering.com can answer all of your questions and supply you with whatever you need. He has been the biggest help to me in that arena and his pricing is very fair.
McClarys's avatar
McClarys
cool ill check into them monday..
thanks
TwistedMinis's avatar
TwistedMinis
I like the QA1 Chromoly line. There are two names they go by, I know XM, and there is another I can't remember right now. HM-Engineering will do your right. I have an account with Ballistic Engineering too, but you have to order from them a lot to keep the prices down, so I've cut back on ordering from them lately.
onehot69stepside's avatar
onehot69stepside
I think the best joint around for 4 links is the super pivot that avs sells: http://www.avsontheweb.com/product.php?productid=766&cat=233&page=1
They have a 1" grade 8 stud tig welded to it but are also available with 3/4" stud or no stud but since you might be wanting to buy alot from somewhere you may have to purchase them blank. The joint is fully rebuildable, just unscrew the end peice with the spanner wrench. I like then because they use the same mounting tab dimensions as a bushing
