semi trailer RIMS sorry not tires
zekefulp@gmail.com's avatar
82standard's avatar
82standard
Just visited a local semi trailer salvage yard I can get aluminum 22.5 for $125 ea is there any reason I cant use them also stealies for $25 ea can I run a 23 in tire on a 22.5 rim? I also can machine my own aluminum s at work. For 22s
Post was last edited on Apr 12, 2013 05:21. Edited 1 time.
82standard's avatar
82standard
Anyone bueller bueller
82standard's avatar
82standard
Please help before I buy and make a big mistake
N
nandrus
If you have the skills to machine your own aluminum wheels then I would do it. If you look around online you can see what people have done to turn them down to a 22" wheel
82standard's avatar
82standard
So trailer rims are the same I was thinkin so but wasnt sure, also csn get studs chrsp too I think ill try my hand at making my own adspters basicall it will be labor Ican find material easily tthanks let ya know how things go
ross_freier
i'm probably going to be doing the same thing in a few weeks once it warms up abit more so i can walk through the local yard up here, the adapters are easy to make aslong as you have access to a mill and lathe adapters and rims will be pretty easy to whip up
82standard's avatar
82standard
Cool I looked at youtube last night under machining 22.5 rims check them out
ross_freier
i just went and picked up a scrap wheel if i get a chance i'll fire it off
rockstar-c10's avatar
rockstar-c10
Aluminum can be milled not steel. But ive seen tires stretched on steel and have never heard of anything bad happening. I personally like the look of steel with low pros better.
82standard's avatar
82standard
I agree I was thinking about stretching also but can't quite decidetheres an s10 crew cab dually on s10 forum stretched
