i jus finished up weld inside of my truck after bodydroppin it...was jus wanderin if its nessecary to take off cab and weld the underside still decidein if i wanna do this or not.....thanks
TwistedMinis
I generally do not pull the cab to weld up the bottom. I do clean the bottom and weld up as much as I can. Getting behind the motor would be tricky, and I generally seam seal that, unless the motor is coming out. On my truck I had the cab off and welded the entire bottom side.
skip1100
ya like seth said just do what you can, but there is no need to pull your cab to get all of it.
