Ask A Pro \  Need Help..
Need Help..
Ask A Pro Q & A
views 244
replies 3
following 2
g9m2c   +1y
Ok so this is my first truck i ever worked on and need Help with the 4 link... Might sound dumb to ya, but I dont really know how to put them on.. I have an idea but not really sure. Oh and where do i relocate the shocks? I am thinking about buying the Super lift triangulated 4 link from suicide.
Description:"In this kit you get a square tubing 4-Link that has 2x2" bottom bars that have a 1/4" wall thickness. The upper bars are made from 1.5" DOM tube with a 1/4" wall thickness, and are fully adjustable. The round ends of the bars are made from high quality mandrel formed DOM tubing and come with urethane bushings. The upper bar ends are 2" in diameter and have a 1/4" wall thickness. The lower bar ends are 2" in diameter with a 1/4" wall. The axle brackets included in the kit are 1/4" thick and CNC laser cut. 9/16" Grade 8 zinc plated bolts, nylon lock nuts, and washers are included.The cantilever brackets are made from 1/4" steel plate and are also CNC laser cut. These brackets weld to the side of your frame. The half circles, and flat circle plates weld to the side of the lower 4-Link bars. Trimming and fitting of the upper plates and gussets is required. It is a complete weld on application."
Can anyone Help me by drawing something up of how to put this on? Sorry for the long post..
BioMax   +1y
There are LOTS of threads about all of your questions. Look around and see what you can find. If you still have questions, let us know and we'll do the best we can to answer them.
g9m2c   +1y
I searched but came out empty handed... The search does not work as well.
This is the kit i was talking about. http://www.suicidedoors.com/4-link-kits/thorbecke-brothers/super-lift-triangulated-4-link-kit It's in my budget and im eager to lay it out. Going to school and it's hard for me to save anything right now..
BioMax   +1y
Check out the sticky in the suspension forum called "BioMax's 4-link article" that should help out a ton.
