york brackets for maz?
thatsmydawg2022@yahoo.com's avatar
thatsmydawg's avatar
thatsmydawg
does anyone make them or is it a straight up custom thing where you make them yourself? not sure how hard it is ive never seen a york in person i dont know whats involved with the tension of the v belt im sure its pretty easy but not sure what else is involved
thatsmydawg
then what do you do for the tensioner? i see thats how you bolt the pump up how do you keep your belt tight?
mazberrydelight's avatar
mazberrydelight
there is no tensioner on it. you slip the belt on before it gets mounted up then fight with it to get it on. hold it real tight and skipped having to design a tensioner.
maz duh's avatar
maz duh
I made one for my Mazda that pivoted on the bottom so I could use a tensioner on it. I had to make the tensioner as well and then measured for a belt. It wasn't too hard to make, I think I had a couple evgs in on making mine.
jdm customs's avatar
jdm customs
The factory mazda rotary type works well too, yorks are sweet tho because of the oil factor.
