Ford Trucks \  Z'ing frame
Z'ing frame
Ford Trucks Make Specific
views 220
replies 4
dortonracing   +1y
what are the benfits of Zing a frame? what exactly is Zing a frame? I hear alot of people talk about it but wasn't sure what it is.
Wicked Fantacies   +1y
The benifits are you will be able to lay frame and not lay at an angle. Theres numerous threads on Z'ing already. But It's raising the front suspension and front crossmember all together so basically you would cut the frame in the distance of lets say between the forwall and the control arm and raise it enough to put the front cross member even with the frame or maybe even a little more depending on suspension geometry and what size tire u wanna run. The you drop the front frame horns down the same amout you Z'ed the frame to the front fender bolts will line up with the rest of the body. I hope this wasn't to vague I've been drinking and not sure if ive explained it well enough. I'll check back in the morning lol
dortonracing   +1y
ok thanks, ok my truck lays frame and we droped the body down where it is laying also. and we didn't z it or anything. should work fine right? layin body on 23's
If your talking about the truck in ur avatar you wont need to z it. Its only in vehicles where the front cross memeber hangs below the frame. So ur good.
dortonracing   +1y
ok thats good to know. I didn't know if i would gain anything extra by doing it or not, thats why i asked. thanks for the help
