Air Ride Suspensions \  i'm switching to slams
Air Ride Suspensions Q & A
views 149
replies 8
following 9
datboychevy   +1y
i have a f/s chevy on firestone 2600s. I dont want to cut anymore so what size re slam has about the same compresed height and diameter?
i have heard that slams lift 1" taller then other bags, if i only run 180psi in my bags will i see a height diference between the slams and stones?
thanks...
disfiguredS10   +1y
I'm thinkin it's the re7 you'll need....180psi should be plenty. I went from the old airlift 2b6 to slam re6's on my s10, and I could tell a huge difference in the psi it takes to achieve the same height.
Low_SST   +1y
thats an re7, on slams site they have a comparison chart so go check it out.
YeLowFuLLSiZe   +1y
i got a 93 full size x-cab chevy and i have re7 slams on my truck and i love them i had a 94 f/s chevy with firestone 2600's and i can tell a difference from firestone 2 slams. SLAMS R BETTER (just my 2 cents)
6galaxy4   +1y
i have re6 slams in my 64 galaxie and it has enough lift to lock up my front end. also hops at 200. you will be fine with the re7
grip   +1y
They feel better because a re7 is a inch bigger than a firestone 2600.
shvdass   +1y
I guess she was right, every inch counts!
DeepSouthS10   +1y
ONLY 180 psi? that seems like kinda alot.
Rigo   +1y
we carry in stock the new dominators if your interested!
