mighty max lowering ?s
flatout5131@yahoo.com's avatar
flatout513's avatar
flatout513
ok so i just bought a 88 mighty max x cab for my daily and i was wondering where to get spindles for it, since i cant seem to find them anywhere? also what is an easy engine swap for that truck?
9
90slammedmitsu
the only company that sells the might max spindles new in unfortunatly
shAIM or u may be able to find a used pair over on http://www.mightyd50.com/forum/index.php
JohnBoy99's avatar
JohnBoy99
also a ton of engine swap info there too.
standardbyker88's avatar
standardbyker88
the eclipse and starion 4 bangers are fairly easy swaps, since they share the same tranny bolt pattern. there are some guys also putting a turbo on that, so there is good potential. mightyd50.com id a great source of info though. and if it helps any, ive installed the aim mm/d50 spindles, and they seem pretty decent of a product. but, that truck, body dropped to the pinch on stock arms, some tube arms the owner brought, aim spindles and 20s had next to zero negative camber laid out. and a shit load of positive aired up. im not sure if it was the arms or spindles that did that, so keep that in mind.
s10
last post by baha +1y
