Ask A Pro \  queston about 24s...
Ask A Pro Q & A
views 262
replies 4
DRGDDLY   +1y
i got a nissan hardbody longbed.... it is my daily and it is bagged...i am not gonna body drop it but i do wanna lay out on 24s and still drive daily.... ive been thinkin and lookin at some different designs and talkin to several people about it... i already found the perfect rims... theyre 24x8s and a set of 24x9.5s the problem is i can only find the info for the 9.5s now..... my question is how do i set up my front bags to get the most lift possible to be able to turn...i am doing a complete back half and narrowing the frame in the rear as well... thanks mad
BioMax   +1y
Haha! So you want me to tell you secret to eternal happiness huh?
What you are asking is for a perfect A-arm front suspension and without spending the time to design a completely new suspension, it will never be better than tollerable. You can push the bags as far in on the lower A-arms as you can and maybe squeeze 10" of total travel out of it, but that's about it without lengthening your arms. And that would probably necessitate moving your motor back several inches.
DRGDDLY   +1y
haha... yep this is gonna be a very entertaining build.... but it will be worth it... thanks
1twztdwagon   +1y
hope you plan on running a tinnnyy tire LoL good luck with the lift an turning daily im on 20s right now i have stock parts modified an it took awhile to figure the geometry with all stock stuff to be able to bd the truck lay a 22 an still drive everyday right now i have 20s with 245 35 20 plan on running a 245 30 22 when i bd it so unbd you maybe able to run a 30 series tire just good luck with it though. i lay full frame front to back with no drop spindles modified uppers an lowers most people would hate on it but its been bagged for over a year ive drive it with no problems drove 85 down i-4 8hrs when i moved to ga had no problems an i have no excessive tire wear like most people say either .. check it out
myspace.com/sikntwztd
Texmextukin   +1y
What size tire you lookin at, a 275/25/24. Thats pretty much the smallest you can get, and i would not daily that tire
