14 Bolt WMS Questions...
jasoncampbell1180@gmail.com's avatar
jcampbell1180's avatar
jcampbell1180
Hai Guise!
Just thinking...
How much narrower is the WMS of the SRW 14 bolt vs. the DRW 14 bolt? Would swapping over to a SRW 14 bolt bring the overall WMS in enough to be able to run the new Eagle 20" dually wheels without any other mods?
gjf's avatar
gjf
DRW is 71 wide wheel mounting surface to wheel mounting surface.
C&C is 63 wide wheel mounting surface to wheel mounting surface.
SRW is 67 wide wheel mounting surface to wheel mounting surface.
The C&C and the SRW housings are the same widths but the hubs on a SRW are offset to the outside by 2".
The C&C uses the same hubs as a DRW rear.
jcampbell1180
