Air Ride Suspensions \  options for airline.....
Air Ride Suspensions Q & A
views 453
replies 12
following 8
granth   +1y
is there an alternative line that looks better than DOT line that comes in half inch? we are going to use slowdowns on each end of the valve so if i want to open it up i can and if i want to slow it down i can do that as well. Is stainless available in half? I'm mainline wanting it for the areas that will be "seen" with the bed and all on. Front end if I pop the hood and that kind of stuff.
KNDAlow   +1y
you might be able to get hydraulic lines in half inch, not sure if itd be available in stainless or not though.
fatboysS1O   +1y
id imagine the have hydraulic line in it. if not, steel braided, should have hardline, and or copper.
fatboysS1O   +1y
steel braided is my fav btw.
granth   +1y
i'd like to have stainless braided. aside from G-W.com I have no idea where to get it. I know the G-W stuff only comes in 4 foot lengths for the 1/2. I'd bet somewhere local would have this stuff seeing as there is a few heavy machine places.
bodydropped85   +1y
napa does hydro line....
granth   +1y
to me that looks just as bad as plastic DOT. Doing what we plan with the truck, i'd like to have each part fit the build.
fatboysS1O   +1y
http://www.gravity-werx.com/index.asp?PageAction=VIEWPROD&ProdID=659
check that link.
if u have a local parker hannifin store. go there. its where GW gets it. ill warn u though, its not cheap.
SHOWTIME   +1y
i used the stainless wire braid with crimp on ends looks good and holds air very nice.It has the teflon insert in it got mine at a local hose shop in town here.It costs a bit but i have had it for about 3-4 years now and looks just as good now.
granth   +1y
check that link.
gotta be cheaper than GW sells it for lol
