Ford Trucks \  check out my work
check out my work
Ford Trucks Make Specific
views 377
replies 16
following 8
instinct   +1y
just uploaded a few pics and looking for any feedback. good or bad thanks!
cheeks Sunset SD   +1y
try again there is no pictures.
unusualfabrication   +1y
Probably not approved yet.
instinct   +1y
try again they are under my profile. thanks man!
waynehammer   +1y
looks great.. only thing i would change would be to plate the frame where the lower link mounts are. even tho it has a big ass gusset the frame isnt that thick and that bracket can be ripped off. happened on my truck when i was driving one time
instinct   +1y
you talkin for the lower bag on bars? thanks man i will consider it.
mindlissmetalfab   +1y
Quality of it looks pretty good but it doesn look very well planned.
That driveshaft crossmember could have run right through the frame to mount your links making your link mounts way stronger. As already mentioned, they will need some beefing up as is. Also mounting your link mounts down towards the ground instead of facing the frame would have let you lower your bag mounts so they came off the frame rail. They look kinda hokey right now.
If you look at the 97 ranger in my profile you'll see what i mean.
Dont take it the wrong way, just as stuff to think about for the next one..
instinct   +1y
nothing personal at all. thanks for feedback. will keep it in mine. this is my first build
ShakinPlates   +1y
Looks nice. I do agree with Wayne, box the frame from the notch to the cab. Its not that hard and makes everything look alot cleaner
