bags for over the axle
doordraggin@yahoo.com's avatar
rizz0's avatar
rizz0
i have heard you say that a sleeve bag is the best bag for over the axle what bag would you run cause everything i see is only 1/4 port is there anything 3/8 out there. also my truck will do some occational towing will the sleeve bags be up to it or should i run a 2800 pound bag
TwistedMinis's avatar
TwistedMinis
Are you worried about the speed with a 1/4" port? Because the Datsun goes up faster than my truck, which is bag over bar.
Anyways, I know that Firestone makes a larger sleeve bag, that is designed to carry a load. Its a little pricier, but its probably what you need. Can be found here:
http://www.ridetech.com/products/Airspring_lb_1T_rolling_sleeve-985-0.html
BioMax's avatar
BioMax
The sleeve bags will drop much faster than they lift, simply because of their design, but they can still lift fairly quick.
I don't think that I would woory so much about the port size, but more about what part is right for my application.
maz duh's avatar
maz duh
Since we are on the sleeve bag topic I was wondering what kind of ride I could expect with a pair of F9000 sleeves mounted over the axle in the back of a nissan hardbody? I haven't been able to find anyone in my area who has a sleeve bag setup to check out in the ride department so I figured I will just ask here. Thanx for the help
BioMax's avatar
BioMax
The sleeve bags are just a hair too soft for my taste on a mini, because it doesn't take that much pressure to lift just a bed. But with a good shock, they can ride really nice. Be extra careful not to over extend then though, the only handle about 10% of the hanging weight of a double convoluted bag.
maz duh's avatar
maz duh
Good to know, thanx Max. Maybe I will just go for a leveraged double convoluted bag instead of the sleeves, with a good set of Bilstiens of course.
