a beer keg?!?!
msbhavn_dodge@budlight.com's avatar
a beer keg?!?!
PHKNOFF's avatar
PHKNOFF
anyone know the max psi a beer keg will hold up to?
OldSkool720's avatar
OldSkool720
???, r u using it for a fuel cell?
PHKNOFF's avatar
PHKNOFF
thinkin bout using it for an air tank
simple-pleasurez's avatar
simple-pleasurez
150 i believe....
laydsuzu's avatar
laydsuzu
not enough lol just put an air tank inside of it to make it look like a keg is being used as the tank, thats what most people do. too big an air tank for me though....
robb1984's avatar
robb1984
I pressure tested one and could only get 120 psig (Coors 15.5 Gallon) before it started to change shape.... I pressure test pipes in plants for a living.
SCINFERNL's avatar
SCINFERNL
Don't do it !!
Beer kegs are used to hold fluid, not air.
When in use, there is approximately 12-15 PSI CO2 in the keg.
If a beer keg should fail, the fluid will absorb the impact of the failure.
If it should fail being used for air storage, it will have nothing to absorb the failure and you will have aluminum shrapnel due to the thin aluminum that the keg is made from...
Steel is malleable, and therefore stretches. Aluminum is far less malleable and tends to fracture.
baggd67galaxie's avatar
baggd67galaxie
Originally posted by SCINFERNL
Don't do it !!
Beer kegs are used to hold fluid, not air. When in use, there is approximately 12-15 PSI CO2 in the keg.
If a beer keg should fail, the fluid will absorb the impact of the failure. If it should fail being used for air storage, it will have nothing to absorb the failure and you will have aluminum shrapnel due to the thin aluminum that the keg is made from...
WHAT HE SAID!!! It makes a big OL BOOOOMMMM!!! I have seen it happen!
obey's avatar
obey
Drink the keg & make it a tank the same night
sloth's avatar
sloth
Edited: 9/24/2008 3:43:53 PM by Sltoh71
30 working psi, I would not recommend using a keg as an air tank. As said above, Build a tank to fit inside the keg. Although, kegs are no longer made of aluminum, they are now made of stainless steel. The old kegs are made of aluminum.
