Chevy/GMC Trucks \  stock floor body drop...?
views 355
replies 11
following 6
superdime   +1y
Edited: 9/24/2008 7:17:26 PM by superdime
what sze do the frame rails need to be... how many inches 2x2 3x3 4x4 i think it is 2x2 or even 2x3 but i just want to make sure... thanx in advance for your help oh and i am talking about doing this 2 an S-10 by the way sry for not specifying
doulovemins   +1y
i go with 2 by 3 and 1/4 wall. make sure the 3 inch is standing when you build it some people lay it flat and I dont think thats safe.
superdime   +1y
thank you so much for your response i am buyig a truck with a custom frame and i think it is 2x3 but the body mounts are too high
crewcabondubs   +1y
i used 2x4x1/4 on mine.
granth   +1y
1/8 works if the person is knowledgeable, 3/16 and 1/4 are more common on full builds though.
superdime   +1y
so if 2x4 will lay rocker then 2x3 will allow me to cut the rocker off?
TBCWORKS   +1y
On our 1990 shop truck project we are using 2x4 1/4 to lay rocker and there is a little more than an inch from the top of the rails to the cab floor. We are not having to cut the trans or drive shaft tunnel at all using a 2 piece drive shaft. True stock floor!
superdime   +1y
so does this mean i should be able to cut the rocker....because it is already pretty messed up and dented.... so why the hell keep it around....lets get low
superdime   +1y
oh and incase someone didnt read my edit i am talking about doing this to an s-10
superdime   +1y
Edited: 1/27/2009 10:05:49 PM by superdime
Edited: 1/27/2009 10:40:21 AM by superdimeso i got the truck and i got the cab off of it and it is 2X4... layed on its side i knowthat is not the best way to do it but... were should i move the cab mounts to... should i flip the mounts and mount it flush with the bottom of the fram and then with the bussings it should mount properly?... i would not mind beeing capable of laying door with stock floor is this possible with 2 inch frame? or do i still need to do some traditional body dropping... if anyone has photos of their stock floor body drop cab mounts i would greatly appreciate it... also 4 of my cab mounts are flush with the top of the frame but the ones in the back are not... can i lay rocker if i drop the back mount to flush with the top of the frame?...the guy that i bought the truck from sucked...he didnt know that he could stock floor the truck so he did traditional and put spacers in the front 4 mounts...idiot   edited  i meant to ask if i could lay door with 2 inch frame or would i need to do some traditional body dropping?.....
