Power window issue on my 07 NBS Duramax
1 following
krewzlo avatar
krewzlo
I have an 07 nbs duramax and the last month or so the power window switch on the drivers door will not work with the door open and the key on. It always did in the past. They work fine when the door is shut but not open. The door chimes still work and the radio will go off when the door is opened after shutting the key off so I don't think it is the door switch. Any ideas? I don't think it is a broken wire as they always work when shut, it seems like if the wires were damaged it would be intermittent either open and shut.
I just put a navi unit in it and used the scosche intergration adapter and the chimes still work and everything else is normal, just not when the door is open. This issue occured before the nav installation so that is not the culprit.
