gas gauge fritz on 99 burb
Kelso
ok i just picked up a 99 burban and the gas gauge never tells what is in the tank it shows its empty or gfull and goes between the two when driving, i was curious if anyone else has had this problem, if so what was it...I wanna know how much gas i have!
W
WebCzar
Edited: 9/22/2008 2:51:13 PM by WebCzar
This is a known issue!
I have a stock daily 2001 Silverado - gas gauge went to sh*t 4 years ago. Took her to the dealer, they said it was the sending unit and would run $1000-1500.00 to fix (lift bed off, drop tank and replace unit)...
I have "lived" with the faulty gauge and I just fill her up, reset the trip counter and go... I now know I need to fill up when the counter hits around 340 miles.
Hope this helps.
Kelso
thanks thats what im prob going to do
choppedcivic98's avatar
choppedcivic98
I have a 00 silverado with the same damn problem, also my power windows and mirrors went to shit on me but o well, besides the small shit i love the truck!!!!
zadaddy's avatar
zadaddy
I had a 98 tahoe that did the same thing. On the fuel sending unit assembly there is a float with an arm that runs against a rheostat (sp?), which in turn is transferred to your gauge to show you how much gas you have.
One of 2 things have happened.... #1 there is junk on the rheostat and it is not reading correctly or #2 the rheostat is faulty.
If you feel like you can change this yourself, you can get the sending unit from any parts store (I work at Advance) for around 300-400 bux tops.
I never fixed mine, just ended up selling it as is. I always used the x amount of dollars = y miles. Just be sure to take into consideration when gas prices go up
