Nissan Trucks \  Need help to fix my nissan
Nissan Trucks Make Specific
views 773
replies 14
following 13
mike86mazda   +1y
I have a 86 nissan with a 3.0 v6 in it. It idles fine and revs up fine untill you reach 2k rpm, once it hits 2k it goes right back down to 800 rpm and sometimes backfires. This is getting frustrating i cant seem to figure it out... anyone have any suggestions? It has a new fuel pump, filter, and spark plugs.
ahab   +1y
Sounds like fuel delivery problem. Check all the fuel lines make sure you flow is good.
97hrdbdy   +1y
Is it fuel injected? If so, did you check the MAF?
CLNSHVNnDRAGGN   +1y
My 97 with 2.4 is doing the exact same thing. It doesn't always backfire but it'll bog down and then go back to normal. I've checked everything I can think of but still can't figure it out.
oldskool66   +1y
well if it backfires its uasually getting to much fuel for the ammount of air. becasue the gas is lighting off in the header. so i would look at your MAF. Just my $.02
mike86mazda   +1y
Thanks for the information guys. im gonna do some more troubleshooting to the fuel system today.. Im going to hook up a inline pressure gauge and see what is going on there... Hopefully I will identify the problem,
I am thinking the pressure regulator might be bad but who knows.....
94NissanLaysDoor   +1y
Any check engine light?
I had a TPS go out once and it was similar
mike86mazda   +1y
Well I noticed the positive conection to the fuel pump at the sendng unit was horribly corroded and not making a good connection, so I fixed that.. I also replaced the fuel pump (it was still under warranty). Now the fucking thing wont run for more than 2 seconds then it dies.. Im about to set this fucker on fire!!!! The check engine light is not on but who knows it could still have a code. I have an ODB2 but no way to get a ODB1.... Anyone have anymore ideas?
draggin95niss   +1y
maybe the fuel pressure regulator...check ur distributor....injectors...als oget a guage and check the fuel pressure im not sure what its supposed to be but the dealer or a chilton manual will tell u and that will tell u about the regulator...
SIC MADE   +1y
my 94 does the same thing used a code reader it comes up with a throttle position sensor haven't changed it out yet to see if it fixes it yet
