2500s on a caprice?
kustumz813@yahoo.com's avatar
2500s on a caprice?
rockstar-c10's avatar
rockstar-c10
Do any of you have 2500s on the front of your caprice/impala bubble? how does it ride and does it get good lift? i know 2600s will get hella lift but i want to lay out and ride low not worried about getting sky high.
time1's avatar
time1
It will probably take more PSI to lift the car up in the front. Just throw the bigger bags in there and be done with it.
TwistedMinis's avatar
TwistedMinis
They compress to the same height so it won't keep you from laying. Also a larger bag will take less pressure to get to your low ride height, and probably ride better as well.
lovetigger88's avatar
lovetigger88
im running 2600's on the front of mine and it rides bad ass and get's good lift. just stay with the 2600's
BDon20s
I run HS-6's on the front of my caprice, with ride height at about 80psi. Just offset the bag 3/4" out from center towards the wheel and it will keep the ride height pressure manageable.
rockstar-c10
Are you running shocks up front?
thalwr1
I got drop spindles for your caprice if you dont already have some. . im in st.pete $200 brand new. . lmk
c10onfire's avatar
c10onfire
I have 2600's, spindles, and shocks up front and she rides like a dream! Go with the 2600's man. You won't be disappointed!
BioMax's avatar
BioMax
The smaller bag WILL have a stiffer ride. I don't care if you move the mount out towards the wheel or not, that is the nature of the beast.
coptic120
I have 4 ply contitech 2600's on the front of mine. Rides very well even with no shocks and it gets alot of lift.
s10
last post by baha +1y
