New guy with a question. Recently bought a 1989 Chevy V3500 4dr, 4x4, 96k. Only upgrade, that I can tell, is that it has 19.5" rims on it with standard truck tires (not low profile). I recently replaced all 4 shocks.
My problem is this. Occasionally, and usually when braking, 30-40 mph, it starts shaking violently. This shaking is coming from the seat and not the steering.
And every once in awhile I will hit a bump at approx the same speed, not braking, I get the same kind of shaking.
I have searched the forums here and the internet and have not found a lot info on this set of symptons. If it happened every time I braked that would be easy but it happens infrequently.
Any suggestions/thoughts would be useful!
Thanks!
dzl1
Welcome to the forum from Florida. Check of this thread.
Hope that helps.
DZL1.
1989v3500
DZL1,
I will definitely checkout the u-joints and driveshafts.
I will say that mine is doing is substantially worse than "vibrating". It's more like violent shaking. It's pretty bad. It doesn't happen all the time so it's hard to diagnose.
