Mini Truckin General \  Bagged truck during winter
views 1032
replies 15
following 11
puddin06   +1y
I was trying to figure out a way to run a bagged truck during the winter when its 12 degrees outside and snowing. I am only really worried about the valves getting stuck open or shut. I plan on running water traps to help. I have heard placing the valves near the exhaust will keep them warm. Anyone else have any ideas on what to do?
Also i may be looking for a dually in the future if you have one that you might want to get rid of bagged or not then message me.
Thanks
do_spiderman   +1y
When I drove mine daily I used to wrap hand warmers around stuff in my bed that would freeze (compressor lines and fittings) and my valves are in my cab. Never had very many issues.
puddin06   +1y
did your valves let out in the cab or did you have them ran out
injunjoe   +1y
ive heard of people putting rubbing alcohol in the tanks. again i dunno how much or if its rubbing alcohol specifically but somethin along that line. hope it helps
dragginbottom   +1y
NITROGEN..............
kaoss   +1y
Air brake antifreez, you get it at the truck stop store. Put your valve closer to the exhaust, run water traps.
soccorjimmy   +1y
Get some ABS antifreeze, it is for air brake systems on the big rigs. I used it on mine when I drove it for ONE winter. I put about one capfull in each tank and it helped to unfreeze the lines and to keep them dry. I will tell you that is the last winter I will drive it in. JIMMY
puddin06   +1y
Well it will be a big truck so i am hoping it will do fine.
pmiller   +1y
air brake antifreeze. drain air tanks daily. drain to remove condensation. water traps are a great idea.
kaoss   +1y
oh yeah, and run silencer/flow controls. This will keep any moister out of the dump valves.
