What size torx driver do I need?
F
flcracker
So I ordered what I thought was the right tamper resistant torx driver from Snap-on to take my horn pad off of my 97 HB but it is waaaaay too small. I ordered a t50. Does anyone know what the correct one is or better yet what the part number is? Thanks
jumbo's avatar
jumbo
Edited: 10/1/2008 11:21:33 PM by jumbo72
is this the torx head bolt with the stud in the middle of the star? You need a torx head with a hole in the middle, right? I helped my buddy take off his horn pad and airbag in his 99 frontier, we just used a small drillbit to drill down the stud, then use a regular torx head. Unless you're planning on putting it back in. Then i can't help, sorry. I was surprised, even if the drillbit got into the grooves a little, there was more than enough left to spin the head easily. ALso helps to hold a shopvac nozzle by the drillbit, much easier to clean up, lol. Hope this helps.
F
flcracker
Yeah the bit has a hole in the middle to fit over that pin and I need to reuse the bolts so I don't want to drill them out. Thanks anyway.
boooghar's avatar
boooghar
go down to harbour freight and buy a complete cheap set for a few bucks, for my garage stuff thats what i use
but i work for CAT for a living and all my stuff is high end with a warrenty
97xenissan's avatar
97xenissan
unless your truck is different i went and checked mine again and its a T50, here is the Snap-on part #FTXR50E should be the same size for all 97,s
Dejavu's avatar
Dejavu
or just get ahold of the correct size regular torques bit and drill a little indention into it to go over the pin in the bolt that our needing to take out.... INSTANT TAMPER RESISTANT TORQUES DRIVER! i understand you already have the set and are just looking for a bigger one, but maybe this idea might be easier than placing an order somewhere.
hope it works!
bodydropped85's avatar
bodydropped85
prob a t55, i dont think they make a t60 tamperproof bit. it goes up to t100 as far as torx tho...
F
flcracker
yeah, 97xenissan you're absolutely right. When I saw how small the driver looked and how big the bolt looked I thought "no way". But it is a t50 so thanks for the info.
97xenissan's avatar
97xenissan
yeah no problem.
