Page 1 of 3
Dodge Trucks \  96 ram on 24's
96 ram on 24's
Dodge Trucks Make Specific
views 1459
replies 22
following 16
blacram96   +1y
looking for some help with back space or off set for 24" rims in the back for my 96 ram so they sit inside the bed fender. thanks
1 LoWfUKn RaM   +1y
your gonna have to narrow your rear end .. kinda impossible with 2g rams to tuck 24s with out narrowing the rear
blacram96   +1y
thanks LoWFUKn RaM thats what i was thinking the 22's i had where close to the bed also. but thought i was missing something. what are you rollin on your ride if you don't mind me asking. again thanks
1 LoWfUKn RaM   +1y
on my ram? if so i got a 94 ford f150 rear end on mine . its 4 inches narrower and you can find those all day
blacram96   +1y
cool thanks for the info. have to check into that. thanks
jeebus @ mmw   +1y
really?
hows that holding up for you man? what did you do about the driveshaft and all that good shit.
thats interesting, something i would consider. What year ford did you get it out of?
also, did the bolt patters happen to be the same also?
Taylor
loudciv   +1y
Edited: 10/3/2008 7:57:38 PM by loudciv
really?
Taylor
taylor, the chrysler 9.25 (our rear) has a speed sensor on top the pumpkin. i can't imagine what kinda of codes you'd get w/o it. and i thought 2nd gens had one there too.
SoloSpecialties   +1y
really?
Taylor
95ish would work,there the same bolt pattern.
blacram96   +1y
adam i beleive the sensor your talking about is for the rear wheel anti lock (rwal) its part of your abs system. the road speed sensor is at the trans. (vss). on plugging the rwal would turn on your abs light but cause no problem with normal brakeing.
1 LoWfUKn RaM   +1y
you are correct and also its the same bolt pattern as a 2g ram
