Chevy/GMC Trucks \  Blazer and S10 Frames
views 112
replies 4
following 5
coreysmith07   +1y
are they the same size. I have a 99 2-door Blazer (2 wheel drive)
will the frame for a 94-97 S10 (2wd) match up?
if so, it would make my life a lot easier when i go to bag the blazer..
Let me know so I can get started on shockin' the show scene=]
LowOrange88   +1y
no, they are different...I'm pretty sure someone else asked about this a while back, you may want to search the forums, I think I remember seeing a few prints, that showed the differences. Also check out s10forum.com. I'm sure there is some more over there about it.
Laterz
lumpy   +1y
the rear section is diffrent for sure above the axel it narrows but front should be the same
travis98s10   +1y
Just think a little more and make your blazer frame work. With all the extra time you will have in a rear frame swap you could have had a really nice custom setup. Suicidedoors has some parts for blazers too if you want to go that route.
AVTekk   +1y
The frames are completely different from the firewall back, even the front clips are different at the body mounts but they use the same bag components..
