yota break booster
toylota91@yahoo.com's avatar
yota break booster
LowToy91's avatar
LowToy91
Im rebuilding my yota (91 4cyl 2wd) completly from frame work to choptop. decided to mount the break booster and m. cylinder behind the cab to the crossmember that was put in. my booster is to big to fit inbetween drive line n lower links. i have been told that the later modle yotas have a smaller booster that my m. cylinder will bolt up to. ive seen the 93 n they are smaller but i want smaller then that. if possible could neone kick me n the right direction on this one?????????
cnudrln
i used all my stuuf off of an 84 4X4
LowToy91's avatar
LowToy91
will my master cyl. bolt up to that year booster???
slammedcivicsi's avatar
slammedcivicsi
a lot of people use the Geo Metro booster.....but If Im reading you correctly your putting the MC and booster behind the cab ? How are you planning on making that work...an elaborate set of linkages perhaps ?
TwistedMinis's avatar
TwistedMinis
Get a 79-83 2WD booster. They are 8" diameter, and will bolt up to your existing MC.
stumbledin
I put mine in the back near the rear axle. easy, use a solid rod from front to back. a geo metro BRAKE not break booster is pimp
