22Re question
tds909@yahoo.com's avatar
22Re question
yota93's avatar
yota93
my truck is ticking like crazy right now,I was told there is a plastic bushing that wears out on the rocker arm, is this true? hope some of you yota guys can help me out thanks
maz duh's avatar
maz duh
If its a valvetrain tick it is probably a stuck or dead hydraulic lifter. Is the motor a high miler or has it been sitting awhile? It's possible that the lifter is just stuck due to sludge and can be freed up by running a good oil cleaner through it. I did a motor swap in a 93 I have and the motor ticked like crazy when I fired it up at first. The motor was a rebuild with about 2500 miles on it. It had sat for a while in the truck I pulled it from and the lifters got stuck. I ran some BG cleaner through it and it shut it right up. Give it a shot and if it doesn't work you will know its probably a dead lifter. Hope this helps
corey0814's avatar
corey0814
22r's don't have hydraulic lifters...they're ajdustable tappets on the end of the rocker shaft. all you need to do is adjust the valve lash with a 12mm wrench & flathead screwdriver. here's how...
http://personal.utulsa.edu/~nathan-buchanan/93fsm/engine/7cylinder.pdf
it's on the adobe page 21 (the manual's page of EG1-35)
skip1100's avatar
skip1100
ya sounds like your valves need to be adjusted.
RARA's avatar
RARA
Yea very normal for a 22r great motor but can be noisy a fuck
slammedtoys's avatar
slammedtoys
is it a tick or is it the timing chaing eating through the timing cover?
