Dually Wheel question
mizzouacidsoul@hotmail.com's avatar
FreelandKustomz's avatar
FreelandKustomz
Ok so im gettin a 97 dually thats bagged on 16s right now. can you run 22s with out a body drop and keep the stock fenders? or body drop it on 19s and not cut the fenders???
okcderek's avatar
okcderek
You can run 16s on inside and 22" Townasty wheel from Tennessee Wheel and Tire on outside and regular 22" up front. 265/35/22 and 225/75/16 are same height. If you run 6 Alcoas you will need to narrow the rear end or widen the fenders. Or run a Cab/Chassis rearend. I have no clue on 19s....
bdydrped's avatar
bdydrped
you can run a 19 with a 35 series tire without havin to do anything to the fenders)depending which rearend you have)bodied
there are 4 widths the cab&chassis, a "normal" size, one an 1" longer ad then the wide track option that i s3" wider if i remember correctly. so you may have to either get teh mounting point milled some to tuck or still have to do a shit ton of fiberglass work
N
never2lowchevy
im running 6 22"s but the rear end had to be narrowed so that it could keep the stock fenders. Just my opinion but the stock fenders look better then the extended fenders... but I want a body drop so ill deal with the exteneded fenders when it comes to that.
