Air Ride Suspensions \  Bagged S-10 Shocks?????
Air Ride Suspensions Q & A
views 193
replies 3
boofmagoof   +1y
What length (collapsed and extended) shocks would you use, front and back, on a bagged 2nd Gen. S-10/Sonoma? Laying frame, bag over axle in rear, shocks relocated in the front...I can't seem to find that kind of info anywhere, surprisingly.
DRAGTHIS   +1y
just measure the length of the mount layed out and fully raised,that will give u the collapsed and extended length of the shock, then go to ur local parts store give them the measurements and u should be able to find a shock. just make sure u tell the guy its a custom fit cause most those num nuts try to go by ur year make and model and get all dumb if u really need help..lol.. damn autozone..
boofmagoof   +1y
The measurements is what I need, actually...as I can not measure it, because it's not bagged yet...I am getting all the parts before it gets bagged.
DRAGTHIS   +1y
Edited: 11/11/2008 3:58:05 AM by DRAGTHIS
well once its bagged get the measurements and you'll be fine.. not much u can do in tell you have the mounts in place(if u modify the rear) and Know the travel your suspension needs.. no one can say u need " 13" collapsed and 16" extended.." seeing as how the trucks no in front of them.. fell me?
