Air Ride Suspensions \  Does anyone know about Z'ing the frame on a 73-91 burban?????????????????????????????
Air Ride Suspensions Q & A
views 448
replies 19
following 15
DOWNHERE   +1y
I have a 79 and I want to know if anyone ever Z'd the frame and if yes, what needs to be done? Meaning, steering rod, transmission, hoses, ect... Is it a headache??? I was told that U dont have to Z the frame by Haggard fab...
Severed701   +1y
i cant tell ya how much work it is..but i know those things pretty much lay pinch when you Z them
KNDAlow   +1y
i dont know for sure when it comes to suburbans but just about every other chevy truck needs to be z'd in order to lay flat. i would think that you pretty much run into the same problems on every z too, again im not positive. As with anything else, every truck may have its own set of problems pending on what parts youre running. if you find out you need to z it, look at other chevy trucks with similar years/models there is plenty of information here on those types. good luck!
tlw32882   +1y
if you dont Z the frame then you must raise the front crossmember but you have to do one or the other to lay frame if it is a half ton
DOWNHERE   +1y
i just need to know exactly what i am getting into... what about raising the crossmember? is it difficult?
tlw32882   +1y
Edited: 11/15/2008 2:13:42 PM by DragaDodge
i dont know of any thread with detailed pics of raising the front cross member but here is a link to a good thread of a Zhttp://streetsourcemag.com/forum/topic.aspx?topic_id=97789&Topic_title=The+Story+So+Far...baggin'+an+87&forum_id=14&forum_title=Full+Size+Truckin+General
another option is the drop member from porter built customs(i think thats there name) any whoo its a bolt in front cross member. the only drawback is, its pricey, but nice to say the least.
turbo94civic   +1y
look at my profile there is some pics of it getting z'd by keef
h2omelon(nick)   +1y
Thorbecke Bros.has a sectioned crossmember now also for a lot less than the porter built.You run into all kinds of issues when you Z the frme on these trucks.You will need to get new steering shafts and some U joints either route you take.The new crossmember is definately the better route.
stumbledin   +1y
Its the same front clip as any other GM fullsize truck from 73-87
I did a Z and a cut off of the lowest part of the frame on an 86. Pics and a tech article on the site.
www.dallashotrodparts.com/1986chevy.html
DOWNHERE   +1y
Thanks thats alot of help... I am a taking the car to a shop to get it done, but bc of the amount of work I was told I shouldnt z the front... Just trying to figure out what to do!
