Chevy/GMC Trucks \  s10 fuel cell ?'s
s10 fuel cell ?'s
views 734
replies 3
NOTLONUF   +1y
just wanted to ask you guys that have installed a fuel cell in your dime or blazer a few questions. are you a guys being able to use your stock fuel pump? also will the sending units the fuel cell comes with work with my stock gas gauge? also if there's any other problems i might run into, that you might have, can you let a brotha know. pre-thanks.
AVTekk   +1y
the 90 ohm sending units that come with the cells will work with your gauge unless you have 98+, i believe they use the 33-240 ohm units. you can get the stock unit to work in aftermarket cells, the older pre-95 setup is the easiest since its all metal, the 96+ is plastic, they both need to be shortened in most cells.
68meets72   +1y
Where did you guys get your s10 fuel cells at? Or did you just custom make them?
NOTLONUF   +1y
thanks alot dave your the man. mine is a 98 so its probably the 33-240 ohm unit, but i'll check to make sure. if it is i should be able to just tell the company i'm buying the cell from and they can send a sending unit for that ohm right? i knew i was gonna have to shorten it either way. thanks again.
oh and for charlie b. i've been looking at cells on ebay there's plenty different sizes, styles, and shapes on there, but i might just have one made not sure yet.
