air bag ??
kyllokustoms@yahoo.com's avatar
air bag ??
jealousonezenvy's avatar
jealousonezenvy
how can i run my valves just for a front up/down and rear up/down set up? how many vlaves will it take... i have fbss but 3valves arent workin anfd there brand new from AVS
mazberrydelight's avatar
mazberrydelight
you need 4 valves for front and rear up and down , another 4 if you want to do side to side
bumlove_blue's avatar
bumlove_blue
you will get air transfer from side to side it the front bags are T-d together and the back will also if T-d together, lots of roll through the corners. Check valves would work great but I think you would need some more valves?
maz duh's avatar
maz duh
If the valves are new won't they warrenty them for you? You will get air shifting with 4 valves which you probably won't care for much.
dragitall
i have front and back with 4 valves and it doesent roll thru the corners or anything it drives fine,but when you ride low and try to turn kinda fast it rolls side to side but you have to make it do it. i'd say go with 4 and you should be fine. who drives theyr truck low and turns sharp anyway. i know driving a bodydrop you cant do that
bodied b2600zx (josh)
ur an idiot.... of course ur gonna get body roll... the weight is gonna transfer no matter what... it does that on normal suspension, let alone air... thats why they make sway bars..
You jus dont know what body roll feels like i guess... :rollseyes:
iRIDElow's avatar
iRIDElow
I had my truck jsut driveable for a little while to get it to a show and 4 valve setup is not the way to go air transfer is a horrible gt 4 more valves and call it a day not ven worth the head ache
dragitall
im pretty sure i know what bodyroll feels like buddy. why are you so hostal? i drive it every day. it works fine. and to mr. know it all
low mazda's avatar
low mazda
at minimum do 6 valves. 4 up front and 2 out back. but i mean, at 35 bux a piece, don't do it cheap just go ahead for all 8. it ain't like they cost that much.
