Chevy/GMC Trucks \  05' Crew Cab on 22's....
views 156
replies 6
following 7
974door   +1y
Wht does it take to make the front of one lay frame?
TEEBAGGINNN   +1y
Remove the inner fenders, relocate everything that mounts to them, cut about an inch out of the passenger firewall at the point and 3 inches out of the drivers side firewall. Control arms(ART) alone will lay as should drop spindles if your tires are not huge.
Lowlife4life   +1y
can anyone give a little more detail as to how to lay the front out, pictures or links to pictures would be great, I also am doing this to my 05 x-cab on 22s.
classicfinishes   +1y
You actually dont have to tub the fiewall on these for 22's. You can use stock arms with a 2" drop spindle. I used a hammer and a block of wood to the point of the firewall to get a little more clearance but thats it. And that was on a 265/35. I would recommend cutting the factory spring pocket off and running and upper plate instead of a cup seems to work a lot better on all the ones i have done.
bodydropped   +1y
ronnie see if aaron hebert still has pics of his truck because his was on 22s but not sure if it laid frame
Lowlife4life   +1y
so what front bag setup could i use? can i just buy cups from FBI or grant customs or maby airride cups with DJM SPINDLES, WILL THAT LAY THE FRONT ON FRAME?
donobird   +1y
ifcustoms.com has a build up of that style truck. its under dannys truck in for 22s
