prop.valve drawing
prop.valve drawing
9
91toylexus
i was wondering if som eone could draw up.or show me some pictures of the proportioning valve where someone has tee'd it off im lost on how to do that.i need to get my truck street ready and that would be sweet.thanks.
9
91toylexus
is it as simple as it sounds? i cant believe i have found anything on here.
lost cause's avatar
lost cause
Yep, It's as easy as it sounds.........
You may not find a brass T with metric threads though,.....I had to cut factory fittings off the brake line and replace them with some that had a more common thread size (then re-flang and flare the brake line)
Hope that helps
slammedcivicsi's avatar
slammedcivicsi
im pretty sure I just used a 1/4" npt fitting. Mine doesnt leak, and appears to work just fine.
