who has switched from airlifts to slams?
9
92yota
i have 2b6's in the front of my truck and 2b7's in the back. i'm switching them all out for re7's. i would assume the rear bags would bolt right up to the brackets because their 2600's, but im switching the front 2500's with 2600's, so will the slam fit my bracket? or could i even drill new holes in it if they don't line up? and the bottom of the bags would be the same right?
idrgbdy's avatar
idrgbdy
i got some old airlift bags that have been installed for awhile and i got new slam re-7's that i'm gonna swap in asap. just heard a lot of people having airlift problems and not too many slam problems. looks like they will just swap right in with no problems. maybe trim some shit around them as they look a little wider.
travis98s10's avatar
travis98s10
The slam bags have 3 holes on the bottom so you can center mount them or use the 2 hole mounts like the airlifts. They will bolt right up, but you will need to make more room up front for the larger bag.
9
92yota
good, so the re7 will bolt to the 2b6 bracket?
Sawed Up's avatar
Sawed Up
Edited: 12/2/2008 1:18:01 PM by Sawed Up
I had 2500lb Airlifts, when I switched to all re7's I had to add clearance (in the bag mount) around the air port. Like nearly a 1/4", the bag mount matched the airlift bags perfectly.
E
ENHANCEDAIRRIDE
I have alot doing the opposite going to the new Doms
