bed mounting???
bed mounting???
9
91toylexus
what are some different ideas on how a bed can be mounted that is over bodydropped? i currently have some 3 inch spacers but is difficult to get the damn socket......well it just sucks the way i have it so some ideas.and pictures would be cool. thanks
TwistedMinis's avatar
TwistedMinis
I usually take some tube, and weld a plate on one end with a nut welded to the back side, or just tapped thicker plate, and weld the other end of the tube to the stock bolt hole location on the bed.
unusualfabrication's avatar
unusualfabrication
I use tubing and then use a piece of the same size tubing cut on a 45, gives you a nice little flat mount with a gusset on each side.
low mazda's avatar
low mazda
pics would probably be helpful. i am sure this one will get confusing
