'88 mazda B2200 front track width?
v8chevyluv@yahoo.com's avatar
airrideluvtruck's avatar
airrideluvtruck
Does anybody know what the track width is on these? I have a chance on getting a front clip real cheap. If its pretty close Im going to put it on the luv so I can keep the 6 lug pattern....
TwistedMinis's avatar
TwistedMinis
If it's too wide, narrow it. There isn't much to it, just narrow the engine cross member and the drag link the same amount.
airrideluvtruck
Ill probably narrow it more than the luv track width so I can drive lower if it allows. Im just worried I might have to narrow it too much and start running into problems with mounting the engine and running the exhaust cause Im trying to keep the stock hood. Reason why Im swapping out the clip is the geometry in the luv suspension. It works good but I dont like the camber especially at the heigth i want to drive it at.
So actually I need the outer width of the frame where you would normally "Z" a toyota and also the track width.
