Ask A Pro \  rear lift bar
rear lift bar
Ask A Pro Q & A
views 274
replies 3
payrion   +1y
im adding rear lift bars for my parallel 4 link, the problem is space between the frame and a wide tire. can i use a lift bar curved like in the crue ms paint pic i have attached?also what is you take on using heims on the axle side of the rear lift bar?Im planning on using heims on the axle side of the 4 link bars as well. this is so i can bring my brackets in closer to gain room.ill taake some actual pics tomorrow and add to this thread..
BioMax   +1y
You always want the bag mounted along the centerline of the bar that is set by its 2 points. In otherwords, you can use a bar that is shaped like you have drawn, but the bag should be mounted on a straight line that is drawn from the center of the pivot point to the center of the pivot point.
I hope that makes a little sense.
menace   +1y
Edited: 12/8/2008 11:52:40 PM by Lowlowriderbike
i understand you max, it would need to be mounted somewhere inline with the yellow line i drew on your diagram, and it magically intersected on the bend of the bar, good placement imo
BioMax   +1y
exactly!
